water pump; please enlighten me?
Old Apr 11, 2004 | 11:32 PM
88RX7LT1's Avatar
My car heats up to extreme, over about 30 miles. Its a progressive problem; it gets warmer despite driving conditions. While the fan kicks on, it keeps getting warmer???
Yes, I've bled the system, and I bled it again today. Little amounts of air escaped; didn't seem significant.
Any ideas???
Old Apr 11, 2004 | 11:44 PM
jcolez28's Avatar
Hey my car did that too. I tried to rule everything out but the true signs of overheating like steam gushing out when I took the rad cap off or knocking noise. Finally I just changed the temp sending unit. I think $10 bucks from the dealer. And that was it.
Old Apr 12, 2004 | 04:19 AM
johnny o's Avatar
Open your rad cap after turning the car on (COLD) and make sure the coolant is swishing around in the rad to verify the water pump is working. Also check your thermostat, you can take it out and boil it in water. I would start with these if you haven't done this already considering you've already bleed the system and you say the fan comes on.
Old Apr 12, 2004 | 11:43 AM
88RX7LT1's Avatar
I thought that the coolant would bypass the radiator until the thermostat opened??
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
