RPM drop
RPM drop
I recently had somethinf funny start happening on my car. When I shift from park (A4) to drive the rpms drop from 1K to like 5 or 6 hundred and it bounces back and forth (1K to 5 or 6 hundred) for a minute the levels out at 1K. Do you think its the IAC or something else. I recently had the car dyno tuned could it be something in the tables ? or IAC valve because sometimes it will even want to die unless I give it gas.. CAM + LOW RPM = no run
..... so I think its the IAC but before I spend 50 $ on it I want your opinion...Thanks
Originally posted by slopokrodrigez
What is your vacuum level?
Edit: one more note to consider. You know how us people with A4 and no line lock kinda brake torque it (without spinning tire) to launch. Well when I hold the brake and get the rpm's up to launch and then let off the gas (no launch) it will die, the PCM for some reason can't catch and hold the idle..
IAC
PCM
help me out guys
NewsBot
Mar 30, 2015 12:40 PM
