Water pump removal...
Old Apr 12, 2004 | 09:38 AM
NewbieWar's Avatar
i cant find the sixth bolt...
im assuming its on the drivers side
because i removed 3 from the passeneger
and only 2 from the drivers side, but i cant find it...
Old Apr 12, 2004 | 10:05 AM
slmdgmc's Avatar
There is a stud there that holds the air pump I believe. You must remove that, then put a deep well socket on the stud and remove it from the block, holding the waterpump on.
Old Apr 12, 2004 | 02:56 PM
Mtrhds94Z's Avatar
Remove the 3 10mm nuts that hold the AIR pump on..
Then there's 2 bolts and a nut on stud [actually 6th WP bolt] that hold the AIR pump cast aluminum mounting bracket on..
then you can get to the 6th WP bolt/stud..
Old Apr 12, 2004 | 08:45 PM
NewbieWar's Avatar
how do i get that alluminum braket off?
Old Apr 12, 2004 | 09:33 PM
NewbieWar's Avatar
i took the coil off and that thing doesnt budge...
is it welded to the engine?
how do u get it off?
Old Apr 12, 2004 | 09:42 PM
Daryn95Z's Avatar
You shouldn't have to touch the coil!
There is one nut and two bolts to take the bracket off.
NewbieWar's Avatar
where? i dont see anything attatched to it?
Old Apr 12, 2004 | 10:00 PM
NewbieWar's Avatar
i dont see the 2 14mm bolts that the instructions say
Old Apr 12, 2004 | 11:10 PM
Daryn95Z's Avatar
2 Bolts
from shoebox's page.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
