just need verification if its the blinker bulb or not
Old Oct 29, 2003 | 09:59 PM
Zack's Avatar
when I use my left turn signale, the light on the dash stays solid, and none of the lights blink(front turn signal or rear). when I turn the hazards on, both lights on the dash blink, and the drivers side rear now blinks, but the drivers side front doesnt blink still. Is it the blub?
also,why would the whole left side not blink if its just the front bubl?
Old Oct 29, 2003 | 10:14 PM
You have a burned out element in the front bulb. The turn signal flasher needs the resistance of the total circuit for it to flash. When an element is burned out, there is less resistance and the flasher won't flash. It is also a good way to let you know to check the bulbs.
Old Oct 30, 2003 | 12:11 AM
MarkyMark's Avatar
Go
yep.......you need a 3157 bulb....autozone or advanced or any auto parts store should have it, in the mean time if you want your back side to flash then you have to do it manually.
________
TeenChick cam
Old Oct 30, 2003 | 12:20 AM
Zack's Avatar
thats what Ive been doin
thanks for the help guys
Aug 24, 2015 11:04 PM
whuzizname
Sep 4, 2002 08:47 PM
panterachik00
3rd Gen / L98 Engine Tech
Jul 10, 2002 07:57 PM
