Stock ride height for a 4th gen?
Old Oct 30, 2003 | 03:36 PM
LWillmann's Avatar
First, some background:
I have this 96 Formula that I love! I'm into stereo systems. I've got a nice system installed in my car, or at least I think it's nice.
Ever since I bought the car though, it's seemed to sit a little low.
And since I installed the stereo system with the box and subs in the trunk, it's gotten even lower in the back.
I know the car will sit down on the bump stops occasionally. With the speakerbox in the car, a look under the rear end will show there is about 1-1/2 inches between the bump stops and the axle tubes.
Last night, I went out and measured from from the ground to the uppermost portion of the fenderwell lip. I measured the car with everything in it that I normally carry in it.
When looking at my lower control arms, they run DOWNHILL to the body from the axle tubes, so I know the car is sitting lower than it should be.
I got measurements of 26-3/4 to 26-7/8 inches at all four corners.
I personally have NOT modified the suspension in any way since I bought the car. I have only added say 150 lbs, give or take a few to the weight of the rear end.
So, here's what I need:
If folks would be so kind as to make the same measurement that I did on their stock suspension car, I'd really appreciate it. I'd like to compare my measurements to stock setup cars. Although I am primarily interested in the Pontiacs, just in case there is difference in the fenderwell dimensions, Camaros are more than welcome here for comparison as well.
I do know that when parking my Formula beside a buddies LT1 Camaro, or my wife's V6 Camaro for that matter, there is a distinctly noticeable difference in ride height, both at the fenders and between the front jack pad and the ground.
Thanks in advance.
Old Oct 30, 2003 | 04:00 PM
BitCypher's Avatar
I know for sure my '96 TA has stock suspension because I'm the original owner. I'll do this for you after I get off work tonight and report back later this evening.
Old Oct 30, 2003 | 04:18 PM
Re: Stock ride height for a 4th gen?
Originally posted by LWillmann
When looking at my lower control arms, they run UPHILL to the body from the axle tubes, so I know the car is sitting lower than it should be.
The lower the car is to the ground, the less "uphill" the arms will look (axle housing>body). On a much lowered car the arms will go "downhill". That is why people buy LCA relocation brackets to restore the "uphill" (or even) angle.
Old Oct 30, 2003 | 04:46 PM
LWillmann's Avatar
I'm sorry, I meant to say downhill to the body and uphill to the axle tubes... I fixed it above... Thanks for bringing my goof to my attention!
Old Oct 30, 2003 | 06:44 PM
Then, nevermind.
Old Oct 31, 2003 | 07:38 AM
LWillmann's Avatar
ttt any one else have any insight or measurements?
Old Oct 31, 2003 | 06:06 PM
BitCypher's Avatar
Okay, sorry for the delay. It's been a busy few days before the weekend. But the weekend is here!! Here's the measurements on my stock-suspension '96 T/A, from the ground to the highest point on each fenderwell (measurement taken on a level concrete surface):
Front-end (driver/pass): 26 5/8 and 26 3/4
Rear-end (driver/pass): 27 5/8 and 27 3/4
Hope this is what you wanted...
Old Oct 31, 2003 | 11:54 PM
LWillmann's Avatar
Thanks BitCypher!
That means that the rear end of my car is about 1" lower than yours. But the front is about level... Interesting.
Old Nov 1, 2003 | 12:30 AM
phrozen's Avatar
there's a good chance they're probably just worn out. Or some dick-head was too cheap to buy lowering springs and just cut the originals. But these are all speculation, I know jack.
canbaufo
May 25, 2015 12:01 PM
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
cmdeshon
Dec 12, 2014 10:51 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
