*Wierd* hesitation/miss/stumble come inside->
Old Oct 28, 2003 | 04:24 PM
MadMaxz28's Avatar
yesterday it was raining pretty bad i was driving my girl home. i dont remember hitting any puddles or anything. it started i was just coasting down hill 3rd gear went to give it a little gas and it felt like it was hesitating like all the motor wasnt there i gave it some more gas it "kicked in" the engine smothed out and spun the tires a little it was doing this all last night and this morning.. got worse later on that night. in first gear leaving a light it would stumble real bad to about 2-2500 rmp then bam it was fine(you could feel it kickin, jerk yer head back). shift to second and stumble again, bam spin the tires smoth out. let off the gas drift alittle give it gas and stumble again.. today it stoped but i did a couple WOT runs and on the shifts it doest "getup" like it used to. sorta feels like it did with my old fuel pump. any ideas? im praying its not the opti.
Old Oct 28, 2003 | 04:45 PM
Stoopalini's Avatar
Sounds like a misfire to me. Maybe a plug wire burnt on a header tube?
Thomas.
Old Oct 28, 2003 | 05:11 PM
95TA8280's Avatar
Definatly soulnds like a misfire. Crapped out opti/plug wire burnt/plug not all the way in.......
Old Oct 28, 2003 | 08:25 PM
MadMaxz28's Avatar
i turned the fuel pressure up a couple days ago for the dyno but i couldnt go so i turned it down again. maybe one of the plugs got fouled? i have a new set of ngk's somewhere. the wires arnt arcing anywhere i checked that
ChickenScreamer94
Jun 2, 2003 09:11 PM
OffspringZ28
May 8, 2003 10:44 AM
Dragons91RS
3rd Gen / L98 Engine Tech
Mar 4, 2003 06:06 PM
eddiezlt1
Feb 14, 2003 05:36 PM
Ninety3Z
Jan 31, 2003 06:10 PM
