Slp Cold Air
Slp Cold Air
ok iv only been on here for a few weeks now. i have a 1997 Z28 camaro 6spd. its a nice car but im trying to put some basic mods to start off. so far i installed the 160 deg thermostrate but i was curious if there was any real way to put in on. i just took the part off and switched therostrats. was that the right thing to do?? plus i just recieved a SLP cold air intake, i need some pics so i can see step by step install could anyone help me out. sorry im new at this. thanks josh
Yeah that is all you really gotta do for the thermostat swap. But to take full advantage of it you might wanna get your fans reprogramed to come on sooner. Or you can get a manual fan switch. I have the SLP CAI. I just used the instructions it came with. It is pretty easy to do. It looks really good and i believe it provided about 7-10 rwhp.
Re: Slp Cold Air
sounds like your gonna have fun,
you'll have to install manual fan switch to turn your fans on early or reprogram your pcm.
your temperture will still rise, untill the fans come on from the factory settings.
I have both (manual fan switch, and a tune for 160 t-stat) I can honestly say I dont use the fan switch anymore, well unless I am at the track or its CRAZY hot out, the tune along doesn't let the temp go over 1/4 (180?) Both are cool to have though
I'm right with ya...just bought a 97 Z28 and just put the SLP CAI on it. Mine came with great installation instuctions including pictures. Was a piece of cake, only took about 45 mins. Hell, took longer to get the filters put on than it did to install the intake. You'll see....
Install Very easy. Where the CAI holds down behind headlights might need to be bent a bit. Install the filters AFTER the CAI is installed. I also cut a square C in the underside splash guard to form a small air scoop.It can be pushed back up if needed.
last month
http://www.bealer.org/enginec.jpg
last week-added a few more things
http://www.bealer.org/bling4.jpg
last month
1msfyter, that is one clean engine compartment. Is there any advantage over having two filters on the SLP compared to having one on the K&N? I've been wondering about the airflow coming from two tubes rather than one, wouldnt the suction be less branching out into two tubes with two filters on it than it would be with just one larger filter?
what did you use to clean it?
Originally posted by Transamdriver
I just stuck the filters on my SLP intake and jammed them through the hole. They got squished a tiny bit, but it was worth it since Im no keeping in very long in favor of "other things".
SLP cold air
thanks for the advice, i was wondering if anyone could show me a pic of what its going to look like after im done under the car, i took the stock air filter and everything off but when i got to the splash guard it is still conected sould i cut it off or screw it back on then set a hole??? also i didnt bleed my thermo, but how do u do that? i started my car up without bleeding it that wont hurt it right? and this kid that i brought this slp cai said that i might need a "recharge kit" for the filters how do i go about that or can i clean them out or just buy new ones? sorry for so many ?'s just trying to learn.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BM93Z
Aug 22, 2002 02:45 PM
