ABS ipon, low trac,Brake lights on.
Old Oct 30, 2003 | 04:39 PM
MonoxideChild's Avatar
I've done some Searches and I've done all that has been suggested.
but, these lights stay on, I've swapped Relays, cleaned all grounds. what is next? Battery is at 13.5 on testing.
what else is there?
Old Oct 30, 2003 | 04:52 PM
americanmusscle's Avatar
Funny thats the same problem I have. Id like to know that answer too.
Old Feb 27, 2004 | 08:58 PM
95 Silver TA's Avatar
I have this same exact problem too...
It started tonite, anyone have any suggestion on what it could be?
Claude
Old Feb 27, 2004 | 09:02 PM
OBE1 95Z28's Avatar
We cured my friend's "light show" by removing the ground stud (passenger side next to the red postivie cap), cleaning the paint off the fender under the stud and reseating the ground stud. This is the ground connection for the ABS sand brake light ignals.
Old Feb 28, 2004 | 09:37 PM
Thanks for the response. I did that today but really have not gotten a chance to go for a long test drive to see if it will last.
I will keep you guys informed if it works for me.
Thx,
Claude
Old Feb 28, 2004 | 11:06 PM
atljar's Avatar
Air in brake lines.
ignition box/spark plug wires playing havoc with ABS control center.
Old Mar 1, 2004 | 10:11 AM
Guys,
I have ~50 Miles on the car since I did the following stuff this weekend and the problem has not come back yet.
I changed my plug wires, I was going to do them anyway since the weather was nice. I noticed 2 of my wires were burnt pretty badly and replaced them with the Over the 'SIDE' valve cover looms and Taylor wires.
I also cleaned all my Ground, The ground next to the Positive ground terminal block was filty. I took it off sanding it down, cleaned off the screw, nuts and all the terminals.
I also check all my other grounds and cleaned them too. I also pulled out the front ABS sensors on the Front driver and passenger side wheel and checked them (they were clean) so I replugged them back on. Also checked the battery and disconnected it to clear all codes.
50 Miles and So far so good. The light show stopped. If it does return, I will check the rear ABS sensors and also bleed the the brakes.
I wanted to thank everyone for thier help and also wanted to post my results (so far) just incase anyone has this same problem. They could do some of the stuff I did and fix this annyoning problem.
Thx,
Claude
Old Mar 3, 2004 | 11:42 AM
Black_Z28's Avatar
Do you have any pictures of this setup? I have OVC style setup and I really dislike it.
Old Mar 3, 2004 | 02:06 PM
I dont have any pics of my own....but you can see them here.
I think these were better for my application because with a blower, I have to vent one of the PCV to atomosphere and add a Valve cover breather, hence I have no room for the wires on top of the valve cover. I really like this set up, it makes it REAL easy to run your wires without making them touch the headers and get burnt.
Check this link and scroll about 1/3 the way down, you will see both the OVC and SVC setup.
http://www.thunderracing.com/index.c...ategoryid=1087
Thanks,
Claude
Old Mar 3, 2004 | 02:08 PM
Hershball's Avatar
i had this problem, its air in the lines, you'll have to bleed out the system or atleast that was what was wrong with mine.
WildRidez
Feb 23, 2015 07:24 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
