Converting MAP readings to vacuum
Old Oct 27, 2003 | 10:46 PM
ead94z28's Avatar
Question Converting MAP readings to vacuum
How do you convert MAP readings to vacuum?
Old Oct 27, 2003 | 11:24 PM
You should be able to find the answer in this write-up from Injuneer.
Old Oct 27, 2003 | 11:31 PM
ead94z28's Avatar
BAR-MAP=Vac. Thank you very much. Any idea what my vac should be at idle?
Old Oct 27, 2003 | 11:41 PM
ead94z28's Avatar
Thanks. I found a normal reading for a stock lt1 to be around 20.5.
DirtyDaveW
Dec 1, 2016 05:37 PM
NewsBot
Mar 13, 2015 07:15 AM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
