Orange or Green Coolant for 95 T/A?
Old Oct 28, 2003 | 02:42 PM
BlackLT1_TX's Avatar
I am doing a flush, and I belive it is the Dextron (orange) stuff. I cant remember exactly, but I do recall the puddle of coolant in my floorboard from my heater core being orange.
Just want to double check, I know with these aluminum heads the orange stuff works best, but I am not sure since it has a iron block.
THanks,
James
Old Oct 28, 2003 | 02:47 PM
Terran2k's Avatar
I use the orange stuff (Dexcool). b/c my car came with it and it says to use it on the radiator shroud.
RamAir95TA's Avatar
I never had any real luck with the orange stuff...
Green is the way to go, as far as I'm concerned.
Old Oct 28, 2003 | 02:52 PM
RedPhenx's Avatar
all of the fbodies ive owned have green in em.
Old Oct 28, 2003 | 02:54 PM
rpm4lalo's Avatar
GREEN.
Old Oct 28, 2003 | 03:33 PM
Patman's Avatar
My 95 Formula is a late production car (5/95) and it came with green coolant, not Dexcool.
I heard a few 95 owners in here who mentioned theirs came with Dexcool, although I also previously thought GM didn't start putting it into these cars until the 97 model year.
Old Oct 28, 2003 | 03:56 PM
moparman's Avatar
Check the sticker on radiator cover. I'm pretty sure '95 and up are Dexcool. There's another thread about this.
Old Oct 28, 2003 | 03:57 PM
Is there any advantage/disadvantage to running either.
I mean, if the car has Orange in it now, should I just go ahead and put orange in it, or would it be better to go with the green?
I know the orange is a bit more expensive, but I really dont care either way.
Old Oct 28, 2003 | 04:08 PM
predator's Avatar
if i were you unless you know for sure you got all the dexcoolout i wouldnt use the glycol because mixing the 2 will cause biiiig problems....do an experiment and mix the 2 in a jar and email me back to tell me what happens
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
scottcba1
Sep 8, 2015 09:52 AM
Pwilson59
Sep 3, 2015 08:47 PM
