Factory Alarm Keeps Going Off
Old Oct 29, 2003 | 01:07 PM
Lost's Avatar
Angry Factory Alarm Keeps Going Off
Yesterday my alarm went off twice within the course of an hour (no one was messing with the car and I didn't hit the panic button).. the goddam alarm then went off a few times while I was in bed and I finally disconnected the battery and manually locked the doors at 5 am this morning (slow learner). Every time the doom light was on as if a door was open/had been opened.. and when I turned the alarm off and then back on again the doom light still didn't shut off as if the car thought a door was still open... but all the doors were definately shut
So here's my guess.. the alarm is aware when a door is opened.. is the alarm on the same switch that triggers the doom light when a door is opened? If so I'm guessing that one of the doom light/alarm switches is shorted or something.. does this make any sense? Where the heck are these switches (including the hatch) and how can I check them? Anyone have a part number for them?
Any advice would be greately appreciated..
Old Oct 29, 2003 | 02:06 PM
HM Murdock's Avatar
Couple o things to check. First, check the hatch cloth, it may be slightly out of place causing it to block off the hatch from shutting correctly. Second thing to do is to turn down the sensitivity of the system. Int he spare tire area, there is a shock sensor near the seat belt. It has a dial on it you can turn down or up. Hope this helps!
Old Oct 29, 2003 | 05:26 PM
Lost's Avatar
I already checked the hatch lock and it appeared to be normal... cloth was not blocking anything. Neither of the doom light switches in the doors appears to be stuck either.. I dunno even know if those are wired to the alarm.. does anyone know if they are? I don't think sensitivity is an issue (though that is handy to know) because there were no loud cars or anything.. no people.. nothing. The alarm just goes off on its own like there's a short or something. Is it possible that something else in the are (like another keychain remote) is interfering with the system on my car?
Help
Edit: if a moderator sees this perhaps they could move or forward this thread to the car audio section.. that might be a better place for this discussion. Thanks
Old Oct 29, 2003 | 06:09 PM
1996 | Z28 SS's Avatar
I had the same problem one night.. alarm just kept going off for no reason every time I locked the car with the remote. Well I played with the sensitivity etc.. did nothing.. so finaly I just didn't lock the car therefore my alarm wouldn't arm so it couldn't go off for no reason. The light inside my car stayed on however.. it always does unless you lock the car.. but if I did the alarm would go off in like 5min. So I just left it but the interior light goes off after 10min as a safetly feature so the battery isn't draind. I just left it over night and had the same problem in the morning.. but after driving it the next day and parking it back home.. haven't had a problem sice... don't know what caused it.. but it's fixed now..
Trevor
Old Oct 29, 2003 | 06:17 PM
HM Murdock's Avatar
It could also have to do with the battery, when you reconnect it, it goes off, and if there is a low voltage situation, it can ramdomly go off. Might be worth checking.
Old Oct 30, 2003 | 12:21 AM
MarkyMark's Avatar
Go
Maybe there is a ghost that keeps setting it off!!!
seriously though.......a quick fix would be to just unplug the sensor by the spare tire. I was having lots of trouble with mine, so i just unplugged it and am going to just go with an aftermarket alarm soon.
________
Buy E Cigarettes
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
