How to properly break in a clutch?
Old Oct 29, 2003 | 08:58 AM
JohnsSS's Avatar
I've been reading many different posts about clutches pros and cons, and always seem to see a reccurring line, "did you break in the clutch correctly?" Is it possible to break in a clutch, if so how?
Thanks.
Old Oct 29, 2003 | 09:07 AM
Hyperspeed97z28's Avatar
You just want to do 500 miles of NORMAL driving, No high rpm's, let it heat cycle a couple times, no burnouts, nothing abusive. just baby it for 500 miles then its good to go bud.
Old Oct 29, 2003 | 09:51 AM
JohnsSS's Avatar
thanks
Old Oct 29, 2003 | 10:19 AM
NVetro's Avatar
yep i agree with Hyperspeed97z28, thats how I broke mine in and it worked out fine.
Old Oct 29, 2003 | 10:29 AM
CamaroBoy96Z28's Avatar
Same here. Back then that was about a week and a half of normal driving which got the break in done pretty quick.
Old Oct 29, 2003 | 10:41 AM
doodad's Avatar
As above, just remember that highway and constant speeds don't count. Needs to be traffic miles.
Old Oct 29, 2003 | 10:53 AM
drewstealth's Avatar
I'm in the process of breaking mine in. How high rpms is to high. I took it to about 4500 about 2 or 3 times to see how much noise the tranny would make.
Old Oct 29, 2003 | 04:25 PM
Z28SORR's Avatar
Not driving at high rpm's. It's the high rpm clutch drops that hurt. Just allow the rpm's to come down before ingaging the next gear. No power shifts.
Old Oct 29, 2003 | 06:57 PM
gb95zconv's Avatar
Of coarse thats city stop and go type miles not highway
Old Oct 29, 2003 | 07:04 PM
turbo_Z's Avatar
all the break in should consist of IMO is pressing in the clutch pedal to make sure its works and if it works w/o making any strange noises then its good to go. the only reason i could see a guy needing to take it easy for 50-500 miles is to make sure its working properly.. theres no wear pattern thats supposed to develope. JMO
Old Oct 29, 2003 | 10:02 PM
Smith's Avatar
I aint never heard of breakin no clutch in so I didnt do it myself. If the flywheel is flat and the pressure plate is flat and the clutch disc in between the two is flat then what has to seat properly or be broken in? I would drive it just long enough to make sure its working then run the hell out of it.
Old Oct 30, 2003 | 08:05 AM
JohnsSS's Avatar
hmmm...i will take what yall have said into thought. carefully noting "Smith's" # of posts no offense Smith
Old Oct 30, 2003 | 06:37 PM
Smith's Avatar
oh yeah i understand i spend more time workin on cars instead of typing about them on here. completely understandable
Old Oct 30, 2003 | 06:38 PM
dobe's Avatar
thats ghey... post count has nothing to do with how much info a person may know
he put his clutch in and made sure everything was right and after 60 miles he had it wide open and spinnin tires... clutch is still grabbing now too
Old Oct 30, 2003 | 06:39 PM
You probably don't have to break in the clutch. But will it hurt it, NO. So you might as well just to be safe.
