500hp N/A All bore no stroke?
Old Oct 28, 2003 | 04:31 PM
dnz28's Avatar
Is this at all possible on a lt1? I see standard 350s all the time with 600 plus hp at the crank. But everytime I look at the lt1 it seems to dive out around 450 or less. For all those I am thinking at the wheels meaning you would need around 600 n/a at the fly. I know that all thing are possible it just depends how much moey you got. So what would it take to get there?
Old Oct 28, 2003 | 05:03 PM
TreySpeed's Avatar
On permanent vacation
Re: 500hp N/A All bore no stroke?
bore isn't the "deal." sure it adds some minimal amount of cubes and unshrouds the valves a touch- but bottom end isn't where the power is
there are guys pushing 420rwhp+ on stock bottom ends. that equates to WELL over 500 at the crank.
Old Oct 28, 2003 | 05:36 PM
dobe's Avatar
Shouldnt be too hard with the right heads/cam combo
my stock bottom end with 142k miles did 409.1rwhp N/A with 17% drivetrain loss thats 478.63 flywheel hp
Old Oct 28, 2003 | 05:46 PM
marshall93z's Avatar
i was going to ask the same question but was going to ask about 450rwhp instead of 500. should be a little easier to obtain.
Old Oct 28, 2003 | 05:54 PM
Rival's Avatar
You can get close to 500 na rwhp. It is going to take: As many cubes as you can get(396 and up) AFR 195, 210, 220 heads ported to the max. A one big cam. What your looking to do few have done. There are a few guys in here that have put down those numbers, but they are the few. And most likely have a good idea of what they are doing. The costs are going to be high.
Old Oct 28, 2003 | 06:26 PM
hsyr's Avatar
If you got the $$$ then give Mindgame a pm. He has over 500+rwhp out of his 383 LT1 If he is willing to share.
Old Oct 28, 2003 | 06:44 PM
dnz28's Avatar
thats the thing I dont want to stroke, any one can bore and stroke to make more hp but its more of a challange to get the same #'s or better out of a 350. So far I have researched for about three weeks and am still researching n/a is the only way to go.
Old Oct 28, 2003 | 09:48 PM
Fast Caddie's Avatar
Many of those big-hp small blocks you're talking about have some unreal head gear. Heads like these:
http://www.gmgoodwrench.com/gmgoodwr...373&section=ep
Scroll on down to see the beasts. The 15* heads Mindgame used (converted) are listed on that page at the bottom. With heads like those you'll have no problem hitting 500+ NA hp if your setup is right. They'll walk all over the 23* castings normally used.
Problem is, heads like the SB2.2s go for over 4 grand a set.
Old Oct 28, 2003 | 09:52 PM
TreySpeed's Avatar
you are going to need a completely forged set of internals-
so why aren't you thinking 396? would make your life a LOT easier with 46 more cubes...
honestly, at that price level, i'm thinking LSx
Old Oct 28, 2003 | 10:25 PM
GhostZ's Avatar
Destroke it and spin it to the moon.
Old Oct 28, 2003 | 10:36 PM
TreySpeed's Avatar
I have still yet to hear a valid performance argument for destroking or against stroking
personal goals and class limitations aside...
Old Oct 28, 2003 | 11:23 PM
Seal's Avatar
or get a ricer, and spin upto 8K
Old Oct 29, 2003 | 12:34 AM
TQdrivenws6's Avatar
Or build a 383 spin it to 8k and eat those FI ricers with all NA power.
With 15 degree heads, lightweight valvetrain, the proper cam, and high revs you could easily build a 500rwhp LT1, just wont be very streetable.
Chris
Old Oct 29, 2003 | 12:36 AM
GhostZ's Avatar
I wouldn't destroke....but he wants to do something different instead of stroking. Why other than to be different, I don't know.
Old Oct 30, 2003 | 12:39 AM
Ai's Avatar
Ai
There's plenty of valid reasons to de-stroke. It's just whether or not they're applicable to these guys that matters .
FWIW.. 500hp NA isn't too bad on a stock displacement shortblock, it just takes a killer topend to do it & keep it driveable .
