checked my fuel pressure, ?
Old Oct 28, 2003 | 04:48 AM
QCKZ28's Avatar
i checked my fuel pressure during a couple of WOT blast in 2nd gear, with the vacuum line disconnected it held steady at 58psi (thats where i have it set for the stock injectors, and programmed the constant at 30lbs) until 5000rpm then it starts to drop off to around 45psi at 6500rpms......that correlates with my air fuel going lean around 5k.....so my fuel pump cant keep up right? i just ordered the cool kit from www.racetronix.com for $150
i also plan to get a set of SVO 30# and turn my psi back to 43.5...
Jesse
Old Oct 28, 2003 | 05:30 AM
rskrause's Avatar
Moderator
Yes, it sounds like your fuel pump isn't up to the job.
Rich Krause
Old Oct 28, 2003 | 05:37 AM
QCKZ28's Avatar
thanks Rich, i just wanted to double check
Jesse
Old Nov 5, 2003 | 10:41 PM
QCKZ28's Avatar
i received and installed my walbro 255lph racetronix kit without any problems, and now my fuel pressure stays where it should be
Old Nov 5, 2003 | 10:53 PM
Just to clarify the test procedure... you don't have to disconnect the vacuum line to test at WOT. There isn't any appreciable vacuum in the intake at WOT. You can leave the line connected.
Old Nov 5, 2003 | 11:41 PM
QCKZ28's Avatar
thanks fred for straightening me out.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
