How good is the 306 on spray?
Old Oct 28, 2003 | 09:17 AM
HM Murdock's Avatar
Just wondering if it responds well. Thanks!
Old Oct 28, 2003 | 10:04 AM
Transamdriver's Avatar
Pretty good I suppose, I ran a test pass on my setup on Saturday and didnt spray the 75shot till after the 330' and still trapped almost 90 in the 1/8th and 111.48 in the 1/4. The temp outside was 80* and everyone was trapping 4mph slower than usual. Im running the CC306 with stock heads also.
Old Oct 28, 2003 | 10:49 AM
96lt1Camaro's Avatar
I hear the cc305 is a better cam for nx. 306 is a better all motor cam.
Old Oct 28, 2003 | 10:53 AM
RamAir95TA's Avatar
You're going to lose some of the spray out the exhaust valve with the 112LS. There are better cams out there for the bottle.
Old Oct 28, 2003 | 11:12 AM
ibanez6rg's Avatar
Joe Brodman runs low 11s with a 306 on spray. 150 shot I think, he said he was going bigger though.
Old Oct 28, 2003 | 02:24 PM
TEA_BRENT's Avatar
Grind that cam on a 114lsa and it is an awesome nitrous shaft. There is always something better, if you wanting a custom nitrous camshaft give me a call and I can get you one.
Old Oct 28, 2003 | 02:31 PM
rpm4lalo's Avatar
306+stock heads+85 shot was 115 mph in the 1/4 with a 3700lb race weight, unfortunatley I could not hook off the line so I only had a 12.79 ET. I also had knock retard on that run, so I think I need a little 100 unleaded at least.
Old Oct 28, 2003 | 03:11 PM
flyinZ's Avatar
I always heard that the 306 didn't utilize nitrous to its fullest...So, if you sprayed 150 shot, then it would probably only burn 100 shot...
IgorT.455/406
Mar 12, 2015 03:39 AM
Fatdog2
Feb 13, 2015 08:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
