Spark plug wire R&R, now it won't idle???
Old Oct 29, 2003 | 12:50 AM
neat's Avatar
Ok, I finished up the cam swap and oil pan gasket change on my 92 vette tonight. After it was all back together it was running fine, but still had an oil leak. I thougyht i could see the leak onthe passenger side so I pulled the wires off the passenger side of the opti and took a closer look. I found the leak, and put the wires back on.
After that, it fires right up, but won't idle. If I rev it and gently let it down to idle, it will idle for about 30 seconds and then die.
IAC maybe?
Old Oct 29, 2003 | 09:41 AM
BitCypher's Avatar
Maybe you partially separated one of the wires from its boot when you pulled it off and now it can't flow enough voltage (if any at all) to fire the plug appropriately? Just an idea...
Measure the resistance/continuity on each of the plug wires and see if one of them stands out above the rest.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
