Best way to make 350-400 RWHP?
Old Oct 30, 2003 | 06:07 PM
AustinZ28's Avatar
Alright heres that deal. My Dad builds racing engines for a living and I want him to make my 94Z28 faster. I talked to him about it and he said that he would like me to get on here and get advice on what others have done and what worked for them.
I would like a respectable amount of power to start with, something that won't start breaking parts. Maybe 350-400 rwhp? I was reading a lot and a head/cam package sounds pretty good. My Dad can P&P the heads for me and do anything machining wise.
Can you guys throw me a couple ideas on exactly what to do to achieve my goal? I want around 350-400 rwhp and I don't want to spend a lot of money on parts. I don't really want a 383 just because I don't want that much power (torque) on a daily driven car.
Thanks in advance ---Brad
Old Oct 30, 2003 | 06:14 PM
badazzcamaro97's Avatar
The head and cam is a good idea, I've also read a good deal into superchargers for good horsepower.
Old Oct 30, 2003 | 06:15 PM
dnz28's Avatar
what are your goals with this car auto x or dragin? need to know
Old Oct 30, 2003 | 06:44 PM
ZDriver96's Avatar
Have your dad port and polist the heads... u can get some SI or manley valves 2.02-1.6 or less like 2.00-1.56 ($ depends, 500-1500). Get a fairly streetable cam like a cc305 XE224/230 or XE230/236 (245).
Jet hot Long tube headers (500), X pipe and dump the exhaust before the axle (custom), Cold air (160).. 52mm throttle body (200-260 check and see if your dad can bore yours or buy one off ebay or the board), 30 pound SVO Ford motor sport injectors (120-200).
Get matching springs, plugs, 1.6 rockers etc..
That is what you'll need to be in the range u want.. all motor. Or u could do long tubes, cold air, exhaust and 100-150 shot of nitrous..
Im going all motor.. got my heads today
Old Oct 30, 2003 | 06:45 PM
dobe's Avatar
got advanced induction ported heads, and a cam from them and i make the nums in the sig.. also have longtubes, 58mm tb, 1.6 rr, etc
Old Oct 30, 2003 | 06:58 PM
AustinZ28's Avatar
Hey bro, I never thanked you for the springs, so thanks. Not sure what I want to do with the car. Can't I just have a daily driver street car that makes 350-400 RWHP? -Brad
Old Oct 30, 2003 | 07:02 PM
AustinZ28's Avatar
Would rather have an all motor LT1 than have to deal with a SC. ---Brad
Old Oct 30, 2003 | 07:07 PM
Cmr0z28's Avatar
Atljar dynod 357rwhp with stock heads and a GM847 cam.....throw some fully ported heads on and you're at over 400rwhp.
check out www.cmotorsports.com they have a ****load of LT1 cams
Old Oct 30, 2003 | 07:08 PM
AustinZ28's Avatar
Thanks for the advice but my Dad can most likely make mine flow better and it will be free.
Old Oct 30, 2003 | 07:16 PM
AustinZ28's Avatar
Thanks for the advice -----> Brad
Old Oct 30, 2003 | 07:43 PM
AustinZ28's Avatar
Anyone else have an idea on a cam? Or what size valves to use? ----------Brad
Old Oct 30, 2003 | 08:10 PM
InGodITrust's Avatar
....see my sig.!!! 362 rwhp and 358 rwt!!!!
Old Oct 30, 2003 | 08:14 PM
Z4 Performance97's Avatar
Get your dad to fix u up on the heads. Then put a cc306 cam in it. Then Hooker long tubes with true duals. Some computer tuning.
If thats not enough for ya JUST SPRAY THE WAY!!!!!!!!! N.O.S. !!!
Old Oct 30, 2003 | 08:21 PM
dnz28's Avatar
well I guess a 350-400 hp monster is just fine for a daily driver. I was just tring to get think of a cam for both situations. well any ways heads and cam are almost automtatic 350-400hp. my set up was dynoed at 385. so if you take a look in the sig that should put you where you want. glad you like the springs. You like the drop?
Old Oct 30, 2003 | 08:37 PM
TreySpeed's Avatar
On permanent vacation
..define "best"
the word LT4 comes to mind if you mean best in a tame way.
Lots of head, tame cam, high lift, full bolt ons and you should have no problem making above 400rwhp and barely loping.
My idea of "best" for a street car is as tame as humanly possible, a low reving as humantly possible, as reliable as humanly possible while still meeting my goals.
Id rather spend an extra $500-$700 to get it tame and lower reving.
