Just put on subframes. What paint do I use for touch up?
Old Oct 30, 2003 | 01:18 PM
stereomandan's Avatar
Question Just put on subframes. What paint do I use for touch up?
I’m hoping one of you guys can help me out. I just put on BMR tubular subframe connecters. I now need to touch up the area where I used the angle grinder to get down to bare metal and also touch up the weld area. Is there a certain paint that is good for this? Do I need to prime it? I also thought of spraying some type of underbody coating around the welds also.
Any advice would be much appreciated.
Thanks,
Dan
Old Oct 30, 2003 | 02:11 PM
Gripenfelter's Avatar
I used black rubberized rocker guard paint.
Old Oct 30, 2003 | 02:15 PM
Thanks for the reply. Where do I find it? Do most autoparts stores carry it? Also, did you prime it at all?
I assume this dries pretty thick?
Dan
Old Oct 30, 2003 | 03:28 PM
Yup most auto parts places have it.
It dries in a foamy/bubbly texture so its got some depth to it. Not much but more than regular paint.
Old Oct 31, 2003 | 12:36 AM
Van5150's Avatar
Noticable difference with subframes ?
Old Oct 31, 2003 | 02:18 AM
94formulabz's Avatar
http://www.personal.psu.edu/users/b/...isc/Subframes/
Here are some pics of mine. I used Rustoleom primer and then black. Its holding up quite well. You can't see the old/new dull/shiny lines after some miles or a drive in the rain, it blends together quite well.
and yes, they are a noticeable recommended mod
-brent
Old Oct 31, 2003 | 10:35 AM
Van5150,
Yes, they make a noticeable difference. It's funny, a lot of times I don't notice them, but everyonce in a while there is a BIG difference. I have one road around here that is blacktop without potholes but is very wavy/bumpy. I noticed it right away. I felt more like I was spanning the bumps rather than twisting with them. I notice it the most twisting the car back and forth. It's a great feeling. No creaks like there used to be. Also, just pulling out of my driveway I can feel the car stays flat rather than twisting and squeeking at the end of the driveway. I'm definately glad I put them on. They don't get rid of all the squeeks because some if them are not body twist related. Any rattles that you have from the dash or interior stuff most likely will still be there because those rattles are caused by impact, bot twisting of the body. My T-tops don't squeek anymore unless it's very cold with a BIG bump.
94formulabz,
Thanks for the info. Your pictures look very good. How long have you had the Rustoleum on there? Looks like very nice welds also. I was lucky. My father in law has a lift and a welder in his pole barn. He did it for free, and I always have access to a lift. Great to have a father-in-law that likes that.
Dan
Old Oct 31, 2003 | 10:55 AM
I've had them on since march of this year. I was very happy with how they turned out.
The stuff Grip used sounds like paint and ok, just be leary of rubberized 'coatings' that isn't really paint and just made to make undercarriges look better right before you sell the car
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
Brake_L8
Jan 20, 2015 09:44 AM
ModdedNerd
Dec 14, 2014 10:28 AM
heavenly_six
Dec 10, 2014 12:23 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
