Scanmaster connections
Old Oct 28, 2003 | 06:09 PM
ibanez6rg's Avatar
In this pic you can see there are quite a few wires. But on my 94, there is 4. That pic is off of a 96. I've got my Scanmaster in and everything, now just stumped as to what to connect to.
My ALDL connector is as follows:
the wires are white (black stripe), black (white stripe), black (white stripe), and tan.
How do you know what connection is what? (i.e. #9, #16)
Old Oct 28, 2003 | 06:20 PM
turbo_Z's Avatar
Re: Scanmaster connections
http://csce.uark.edu/~jgbertr/rb/dlc1.jpg
the red goes in the 12 volt(#16)... white is data(#9) and black is ground(#4)
oh sorry i didnt see the wires are completely different colors. if you can figure out what color corrisponds though then what i said still applies.. weird they are so different.
Old Oct 28, 2003 | 06:24 PM
Brandon 95 Z28's Avatar
Should be the tan ALDL wire for the scanmaster's white wire.
Old Oct 28, 2003 | 06:36 PM
ibanez6rg's Avatar
[ ] [ ] [ ] [ ] [B] [A]
[G] [ ] [ ] [ ] [ ] [M]
OK, shoebox's pic helps a ton!
G - Keyless entry (forget about that one)
B - Diagnostic Terminal and
M - Serial Data
M is tan, so I hook up the white ScanMaster wire to it.
A - Ground
What about power?
thanks guys
Old Oct 28, 2003 | 06:39 PM
Just use a test light to find a power wire under the dash, there are plenty there they have power in the accy position, I used a red one. I didnt like using all the ALDL connections for my power and ground because they are harder to access. If you have an alarm, you should have an abundance of power and ground wires to choose from under there.
Brandon
Old Oct 28, 2003 | 08:28 PM
ibanez6rg's Avatar
Got her connected! Pretty cool scanning tool, can't wait to test it out tomorrow
Atleast I have no knock retard at idle, eh?
Old Oct 29, 2003 | 02:02 PM
You would have found the wiring instruction in my ScanMaster writeup.
If you use an HPP, or ever need to connect any other scan device to the ALDL, you will need to have a way to disconnect the white ScanMaster data wire. I put a tiny switch right on the ALDL connector surround.
Old Oct 29, 2003 | 02:14 PM
ibanez6rg's Avatar
Yea Fred I read that last night, must be why I'm so tired today
Old Oct 29, 2003 | 02:22 PM
turbo_Z's Avatar
hey sorry i saw you saying something about a 96 and didnt notice you actually had a 94 but i have a friend who has a 94 and we couldnt get my scanmaster to work on his car so i was just wonderin what 12v power source you used and where you plugged the data wire in at? we used Robs tech page too so i was lost.. got it to come on a couple times but never long enough to read it.
Old Oct 29, 2003 | 02:29 PM
ibanez6rg's Avatar
The data wire I connected into the ALDL connecter (tan wire)
[G] [ ] [ ] [ ] [ ] [M] <-
The power and ground I just took over to the radio. I didn't feel like cutting into many wires under there... It's scary.
Old Oct 29, 2003 | 04:37 PM
LimitedEd1LE's Avatar
Just run the ground to any good ground in the car. I used a battery bar from a hobbie shop and connected the red wire to it and plugged it into the ignition fuse place on the fuse panel. Works great on my friends 94...still waiting to get it into my car.
Old Oct 29, 2003 | 04:50 PM
battosai's Avatar
ibanez6rg did you mount yours in the A/C vent? It took me a while to dremel mine out and it barely fit.
Old Oct 29, 2003 | 04:55 PM
Thats where everyone mounts it. I mounted my buddies in the AC vent. I just cut off the long ends on the vent and then that sucker down. It fits very nice.
Has anyone mounted that in a different place other than the AC vent for a 94-95 Z28?
Old Oct 29, 2003 | 04:59 PM
ibanez6rg's Avatar
Yea I put mine in the vent. I used a Dremel and got it to fit in very well. For me that was the easiest part.
Old Oct 29, 2003 | 05:24 PM
battosai's Avatar
Ya clearing the vent wasn't that bad. I just went slow so it wouldn't look like a hack job. The wiring was a pain; not that it was hard to hook up. Just could have used a little more slack in the aldl wires.
Nayr
Mar 3, 2023 08:34 PM
marlar98
Sep 12, 2018 07:18 AM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
