Correct o2 sensor?
Old Oct 28, 2003 | 12:29 PM
AxeGrinder30thZ's Avatar
Correct o2 sensor?
I need to replace the front passenger 02 sensor in my 97 Camaro Z28. Is this the right one? Picture of o2 sensor
It's part # 25312184. Thanks.
Old Oct 28, 2003 | 12:59 PM
BitCypher's Avatar
For the front O2s (94-97), yes, I believe that part number is correct. (http://www.csce.uark.edu/~jgbertr/rb/Parts.htm)
Old Oct 28, 2003 | 01:04 PM
NewbieWar's Avatar
ok and there are 4 sensors am i correct?
do all of them need to be replaced?
and where are they all located?
Old Oct 28, 2003 | 01:09 PM
BitCypher's Avatar
Depends on the year of LT1. Cars with dual cats ('96-'97) have 4 sensors: one before and after each catalytic converter.
Old Oct 28, 2003 | 01:13 PM
NewbieWar's Avatar
but my 94 only has 2 sensors ?
Old Oct 28, 2003 | 01:16 PM
turbo_Z's Avatar
correct. you have 2 heated O2 sensors in the collector of your exhaust manifolds.
Old Oct 28, 2003 | 01:19 PM
BitCypher's Avatar
More specifically, the reason that '96 and newer f-bodies have 4 oxygen sensors is because of the introduction of the OBD2 (a.k.a. OBDII) computer and dual catalytic converters in '96. This updated computer (PCM) has two extra sensors, one behind each cat, to monitor the health of the catalytic converters; basically to make sure the cats are doing their job. Just a tidbit of history.
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 21, 2015 11:28 PM
sloppytot
Feb 25, 2015 08:30 PM
Jul 4, 2005 05:00 PM
