Rearend Damage?
Old Oct 29, 2003 | 06:51 PM
TArider21's Avatar
Question Rearend Damage?
OK, here's the scenario: My 1994 Trans Am's rear differential has been howling for quite some time now, about 3 months, what lead up to this was the pinion seal going bad, and the rear ran pretty dry for a week or so. What I need to know is if I am further damaging my rearend by driving it like this, I can't get my gears installed for about 2 more weeks because my mechanic is busy on other cars. Any insight into my problem will be very appreciated.
Old Oct 30, 2003 | 06:17 AM
IDOXLR8's Avatar
Did you put my rearend fluid in your car? The same happen to me and I ended up chewing up my ring gear, pinion gear and reluctor wheel. I would be careful.
Old Oct 30, 2003 | 06:26 AM
funina91ss's Avatar
If you ran it dry I would replace all the bearings too. And its hard to tell what might of happened to the limited slip. Just let him look it over real good. But in the future, Don't let it go dry agian But if you want to drive it "fill it up" and go.
68camaroboltz
Oct 5, 2015 01:46 PM
DelSoto
Sep 19, 2015 05:31 AM
blaze309
Sep 8, 2015 05:27 PM
themex2002
Sep 2, 2015 03:47 PM
