50lb fuel injectors?? help
Old Oct 28, 2003 | 08:48 PM
BigTed187's Avatar
i have a 95 z28 and i was wondering if 50lb delphi fuel injectors are ok for it cuz i have clogged fuel injectors now with 150k miles on the car....thanx alot
Old Oct 28, 2003 | 08:50 PM
rskrause's Avatar
Moderator
You would need reprograming touse them. And unless you are making serious hp, you don't need them.
Rich Krause
Old Oct 28, 2003 | 08:51 PM
BigTed187's Avatar
what should i go with theN?? like 30lb?? or around there??
Old Oct 28, 2003 | 08:56 PM
VeryBad's Avatar
The 50# will be way too big without PCM tuning.
If you need injectors or need to get them serviced, let me know.
Gordon
http://www.witchhunter.com
Old Oct 28, 2003 | 09:01 PM
96speed's Avatar
Stock injectors are plenty for a stock motor. What are your mods?
You can't just add bigger injectors - you need airflow to supplement the fuel to make power. More fuel to a stock motor will just make you run rich.
Ryan
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
