Question about LT headers?
Old Oct 28, 2003 | 09:33 AM
TommyWei16's Avatar
will i have to remove the cat if i put in long tube headers? anything else should i know?
Old Oct 28, 2003 | 09:34 AM
HM Murdock's Avatar
Yes, the cat will have to be removed for header installation. It will be pushed back towards the rear of the car.
Old Oct 28, 2003 | 10:27 AM
BitCypher's Avatar
It's usually good to review the parts and processes that are consumed/executed when installing LTs. The information may prove useful to you and answer some questions... a thread for you: http://web.camaross.com/forums/showt...hreadid=186318
Old Oct 28, 2003 | 11:14 AM
CamaroBoy96Z28's Avatar
Unless you get Jet-Hots LTs with emmisions junk on it, your EGR and AIR have to go but I'm sure you knew that. Cats will be pushed back, or you can just not run them like some of us without emissions testing do if you dont have it either. More than likely you will need to jack up the engine at least on the pass. side. Also you should go with over the valve cover wires for ease of installation and maintenence, but you can always route the wires in the stock location without any problems. With OVC wires, you will need a universal set that you cut and crimp yourself which is very easy to do.
Old Oct 28, 2003 | 11:15 AM
ibanez6rg's Avatar
Kill the cats!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
