wierd tranny rattles
Old Oct 28, 2003 | 08:07 PM
Blue89Bird's Avatar
ok, my clutch doesn't slip but.....
Lets say you have the car out of gear, and you rev the engine you can hear a rattle of sorts, and sort of feel it if you put your foot on the clutch (but not depressing it)
If you push the clutch pedal in, and rev it, you have no rattle whatsoever.
Sometimes when taking off in first gear, while youre taking your foot off of the clutch, you get a nasty grinding noise, but it's only when you have the clutch pedal at the same exact position and if you push the clutch in or take your foot off the pedal the noise goes away completely.
Any suggestions?
Old Oct 28, 2003 | 08:15 PM
NVetro's Avatar
what type of clutch do you have? If its an aftermarket clutch it is most liklet clutch chatter. If you have a stocker still,then it mite be your throwout merring or pillot berring starting to go.
Old Oct 28, 2003 | 08:19 PM
Blue89Bird's Avatar
it was replaced last year by the previous owner. I was told it was a "high performance" clutch and it was done at the local dealer so I'm assuming its an LT4 clutch of some sort. It never did this up until about 3 months ago, is this normal "chatter" what exactly is chatter, will it cause premature wear of any sort, or is there a way to get rid of it or is it something you just have to deal with?
Old Oct 28, 2003 | 10:09 PM
Blue89Bird's Avatar
sorry guys, forgot about the driveline forum, I'll repost it there
*edit*
here's the link
http://web.camaross.com/forums/showt...hreadid=186976
Old Oct 30, 2003 | 10:53 PM
Blue89Bird's Avatar
Exclamation
TTT
PLEASE
HELP
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
