Oil Questions. Convert to Synthetics?
Old Oct 30, 2003 | 04:26 PM
Eddie Z-28's Avatar
Question Oil Questions. Convert to Synthetics?
I'm wondering now with 86k on the clock of my Z, should I convert it to synthetics, swtich it to a high mileage regular oil, or just keep going on with using the regular stuff? Could someone please expand on this for me so I can keep the motor running strong?
Old Oct 30, 2003 | 04:44 PM
S.J.S.'s Avatar
I would keep using the regular dino oil and just change it every 3k miles or less. People have had problems with leaks after switching at high mileage.
Old Oct 30, 2003 | 04:52 PM
Eddie Z-28's Avatar
What about using a Max Life Oil for cars that high higer milage? Would it be good?
Old Oct 30, 2003 | 05:02 PM
S.J.S.'s Avatar
Personally... I wouldn't go with max life just yet. You could upgrade to a good 10-40w.
Old Oct 30, 2003 | 06:21 PM
badazzcamaro97's Avatar
I have 84,000 on the clock and I still use 10w-30.I was advised against synthetic with this mileage because it could result in an oil leaks.
Old Oct 30, 2003 | 06:49 PM
RedPhenx's Avatar
HEYZEUS!! sythetic does not cause leaks. I switched at 105k no problems 25k miles later. you should be ok.
Old Oct 30, 2003 | 08:17 PM
Mtrhds94Z's Avatar
I changed to synthetic at 123K and now have 142K.
It didn't 'start any leaks'.
rideordie
Nov 5, 2019 04:52 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
captcorvette
Mar 7, 2015 12:37 PM
squarehead
Nov 21, 2014 08:02 PM
