No heat
Old Oct 28, 2003 | 12:45 AM
Big_TA's Avatar
Unhappy No heat
I have a 1995 TA. Today I turned on my heat and my fan was blowing out the same air maybe a little warmer than out side. Whats most like;y the reason? Is there a common thing that usually brakes or goes on these types of cars?
Old Oct 28, 2003 | 12:46 AM
Seal's Avatar
that could be very well related to your cooling system in your car!
Old Oct 28, 2003 | 12:54 AM
ead94z28's Avatar
Try flushing your heater core.
Old Oct 28, 2003 | 05:52 AM
Mr Kevlar's Avatar
What was your Engine temp at? With my 160 in the winter time, the engine never get above 180. In turn the heater sucks! I usually swap the 180 stat for the winter stat. If your engine is at normal temp 200-210 try flushing the core like stated above. Could also be your heater door cable not opening the heater door enough. But every Fbody i've been in had a somewhat crappy heater.
Old Oct 28, 2003 | 07:46 AM
sikz28's Avatar
Even with a 160 t-stat you should have plenty of heat it just takes longer to get hot. You need to back flush your heater core.
Old Oct 28, 2003 | 10:47 AM
JWA95TA's Avatar
yup back flush the heater core. that is what I had to do. But I now have to do it again. My heat has gotten back to where it is not hot. I think the fact I did it with the heater core being higher the the rest of my cooling system . I dunno. This time it will be on an icline with the heater core being lower then the rest of the system.
Jason
Old Oct 28, 2003 | 04:10 PM
Big_TA's Avatar
Thanks guys i'll try that.
Old Nov 23, 2003 | 06:22 PM
BlutoZ93's Avatar
Thumbs up
Hey, I just wanted to thank everyone for their help. I was having the heater problem as well and the heater core back flush has it roasting again. I don't need a Chiltons with this forum around.
Old Nov 24, 2003 | 09:08 PM
Josh'95Z28conv's Avatar
You had a problem, you did a search, you fixed your car. You didnt make another pointless thread like many others.
You are the man
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
