Did clutch install...Still a problem.
Old Oct 28, 2003 | 10:38 AM
drewstealth's Avatar
I installed my mcleod single disc, PP, and flywheel over the weekend. The car seems to drive good. The only thing is the clutch petal is very soft. It also engages pretty high up. The worst part of it is that when i got to work today i smelt the same smell that i smelt before. Which i'm pretty sure is burnt clutch. When i pulled out my slp clutch the disc was actually in very good condition. My power steering pump shoots fluid out sometimes. Do you think that this could be the smell and not the clutch? Also is there a good guide on how to bleed your clutch? I have a chiltons manual but it is very confusing to me in there.
Old Oct 28, 2003 | 11:10 AM
carlos64030's Avatar
Check out this site: www.caspeed.com/gallery13/index.html
Old Oct 28, 2003 | 11:58 AM
KCFormula's Avatar
How many times has your flywheel been turned? I have heard stories of LT1 flywheels being too thin and actually causing some clutches to engage funny.
Also the best way to bleed your hydrolic system is to take it all out and bench bleed it. Its a PITA but IMHO worth it in peace of mind.
Old Oct 28, 2003 | 12:07 PM
The flywheel is a brand new one from mcleod.
Old Oct 28, 2003 | 02:56 PM
Is it supposed to engage really high like that on a new clutch? I thought if it was a new clutch it would engage lower and as it wore down it would start to engage higher up.
Old Oct 28, 2003 | 05:09 PM
ttt
Ericksd
Jan 20, 2016 06:07 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Ericksd
Sep 16, 2015 07:08 PM
mmf_1013
Sep 12, 2015 08:56 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
