stock rocker help needed asap
Old Oct 27, 2003 | 11:22 PM
deadhead1882's Avatar
ive got a 95 z28, with what im assuming r stock rockers, its been making a funny kinda knocking/clicking/clanking noise, anyways ive got the valve cover off and 6 of the 8 on the pass side or pretty loose, they move side to side and the valve gets off set when i move the rocker. how tight do i need the rockers to be, how much torque, r they supposed to be that loose. any help is greatly appreciated as i need to have this done by the morning
Old Oct 27, 2003 | 11:26 PM
97bowtie's Avatar
The rocker should move side to side...the two that won't move side to side have pressure on them from the valve being open. As long as there is no gap between the rocker and the pushrod/valve, they should be fine. Are any of the jam nuts loose on any of the rockers?
Old Oct 27, 2003 | 11:28 PM
what do u mean jam nuts, i havent tried tightening them yet cus i dont wanna possibly over torque them
Old Oct 27, 2003 | 11:36 PM
97bowtie's Avatar
OK.
The rocker sits on a 3/8" stud which is attached to the head. The rocker arm sits on this stud and above the rocker arm is a jam nut (looks like a regular nut). Inside the jam nut is a poly lock. If you have a loose rocker arm, the poly lock/nut will most likely be loose. The poly lock uses an allan wrench (I want to say a 7/32" but I'm not certain). Check that both the nut and the poly lock are tight.
Next, check for any excessive play in the rocker arms. If there is a gap between the rocker arm and the valve/pushrod, you may have a loose rocker, collapsed lifter, bent valve or bent pushrod...but it's most likely a loose rocker. If there is no upward/downward play your rockers are most likely OK.
Describe the noise a little better if you can.
Old Oct 27, 2003 | 11:39 PM
NOMAD's Avatar
Stock rockers don't have jam nuts, your thinking roller rockers
Start the car and tighten them ones making the noise until they stop making the clacking, then take it about 1/2 turn extra and see if that does it
-Shannon
Old Oct 27, 2003 | 11:40 PM
it actually sounds like a chirping, its not a systematic thing, its really hard to explain, ive been thinking it might possibly be an injector but not sure what a bad one would sound like
Old Oct 27, 2003 | 11:41 PM
97bowtie's Avatar
-Shannon
lol, thanks. Been so long since I have seen a factory rocker. Disregard most of what I said deadhead.
Old Oct 27, 2003 | 11:44 PM
NOMAD's Avatar
Don't feel bad, I typed almost the exact same thing before I re-read the post to see which brand he had...Lol
-Shannon
Old Oct 27, 2003 | 11:46 PM
ok i was gonna say i cant find the jam nut ur talking about. will starting the car with the valve cover off hurt it, or do any damage
Old Oct 27, 2003 | 11:49 PM
97bowtie's Avatar
Starting the car with the valve cover off won't hurt anything. Do as Shannon said and let us know.
Old Oct 27, 2003 | 11:53 PM
will it blow oil or anything all over the place
Old Oct 28, 2003 | 12:00 AM
97bowtie's Avatar
Only if you rev it up somewhat high.
Old Oct 28, 2003 | 12:17 AM
this is gonna sound really stupid, but how do u get the tensioner to move in order to get the belt on. i had to move the alternator to get the cover off
Old Oct 28, 2003 | 12:37 AM
ive gotta get the belt back on before i can start the car, and it wont go on the same way i got it off
Old Oct 28, 2003 | 12:41 AM
97bowtie's Avatar
You can actually run the car for quite a while w/the belt off. It will run off the battery for quite a while. I wouldn't run it more than 5-10 minutes w/out the belt on though.
