EGR Removal
Old Oct 16, 2003 | 12:58 PM
HectorM52's Avatar
EGR Removal
What all do I have to do to remove the EGR?
1- Remove EGR Pump
2- Program Out EGR
3- Put On Block Off Plate
4- Remove Hoses (do I just cap the ones off that go to the side of the intake?)
5- Remove Wires From Harness
IS THIS CORRECT? Do I need to do other things?
Old Oct 16, 2003 | 01:00 PM
95_RipperZ's Avatar
Sounds like you got it all. Make sure to cap the side vacuum holes it uses. I forgot that when I did mine.
Old Oct 16, 2003 | 01:04 PM
HectorM52's Avatar
So there is actually a part of the PCM program that I have to mess with?
Do you know what the advantages to doing this are??
Old Oct 16, 2003 | 01:16 PM
ibanez6rg's Avatar
OBDII the computer needs it deleted. There is no gains from this removal really. Get's junk out of the way though.
Old Oct 16, 2003 | 01:20 PM
HectorM52's Avatar
I thought I had read that about being no gains...
Oh well, it cleans everything up like you said!
And that big pipe next to it is part of the system too. I didn't know that, I thought they were seperate??
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
