what is this
Old Oct 16, 2003 | 01:43 PM
95Zdroptop's Avatar
what is this
On top of the driver side valve coverthere is a cylinder looking device that has a cover that says throttle response or something. Every picture i look of a camaro engine they dont have it there. Did everybody move theres or get rid of it.
Old Oct 16, 2003 | 01:44 PM
Gripenfelter's Avatar
TCS?
Traction Control.
Old Oct 16, 2003 | 02:22 PM
Black_Z28's Avatar
That would be the Traction Control. If you take that black plastic box off it will say Bousch on it.
Old Oct 17, 2003 | 01:03 AM
95Zdroptop's Avatar
Okay. But why do I see a lot of cars without it. I would like to clean up my engine bay a little bit
Old Oct 17, 2003 | 01:27 AM
aintno6's Avatar
It was an option not a standard. I have to say 1/4 4th gen I have seen in person have it. LoL. Dunno maybe its just me.
Old Oct 17, 2003 | 02:07 PM
Even as an option, it wasn't actually available until part way through the 1995 model year. So you will not see any 93 or 94 models with it.
Old Oct 17, 2003 | 02:19 PM
grygst76's Avatar
Not true, My 94 has the idiot light for traction control, but it never was installed.
Old Oct 17, 2003 | 02:28 PM
lt1hatesme's Avatar
my 94 z28 has TC. i know because when i have to brake real hard all of a sudden, the car seems to give up braking and roll a little further at the end, like its trying to keep from loosing traction and the low traction light comes on.
Old Oct 17, 2003 | 03:04 PM
Yes... the "LOW TRAC" light was installed in the dash, because they EXPECTED to make the traction control option available in 1994, but they had production problems, and it was never available. Then they advertised it in the 1995 brochures, but didn't make it available until later in the year, because they still had the production problems.
Do you have traction control?
lt1hatesme:
Since you are sure you have TCS, do you have the big black box bolted to the top of your driver's side valve cover? Do you have a TCS defeat switch on your console? When you floor it, does TCS prevent you from losing traction and spinning the wheels?
What you are describing it not the action of the TCS system. What you are describing is the action of the ABS system (perhaps not working correctly) and the "LOW TRAC" light is coming on to show that your ABS is activated.
Old Oct 17, 2003 | 03:10 PM
Larnach's Avatar
That's what we call ABS ASR will occur when you floor it from a stop and you get the pedal kicking your leg back.
Old Oct 17, 2003 | 04:14 PM
grygst76's Avatar
lt1hatesme:
I'm sorry I wasn't more elaborate...I HAD traction control on my car..It was taken out by the dealer per customer request after the car was delivered according to the dealer my car came from (service records) The owner did not ask for it and it was delivered with it so the customer wanted it removed or he was giving the car back, My buddy works at the dealership and pulled the records. Same as my OBD2 connector instead of OBD1. too many variables at the end of the year when my car was made.
Old Oct 17, 2003 | 06:38 PM
lt1hatesme's Avatar
lt1hatesme:
well then...
i guess i dont have Traction Control. my bust.
