neutral safety/reverse lights switches and wires
Old Oct 14, 2003 | 08:04 PM
TAChad's Avatar
I bought a B&M hammer shifter to go with my TH350 install, and im trying to figure out wich wires are for reverse lights and neutral safety. I figured out those but there are 2 more wires left(6 all together) that i dont know what they are, one is black with white stripe and the other is orange. I took apart the gear selector switch and it looks like those wires are switched on in either 1st or 2nd gear. anyone know what those are for? thanks
Chad
Old Oct 14, 2003 | 08:23 PM
The blk/wht is a ground. Orn/blk goes to the park/neutral position input to the pcm, hatch release relay and to the brake-transmission shift interlock (BTSI) solenoid (for automatics).
Old Oct 14, 2003 | 08:32 PM
TAChad's Avatar
whats the brake transmission interlock for? im wondering how im going to hook these up with the hammer shifter
Chad
Old Oct 14, 2003 | 08:58 PM
Chad
It's the thing that won't let you shift out of park unless the brake is depressed. If there is no mechanical connection of the BTSI linkage to your new shifter it won't matter.
Old Oct 15, 2003 | 09:08 PM
TAChad's Avatar
ok, thanks for your help
Chad
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
Jul 4, 2005 05:00 PM
Omega9
Aug 2, 2002 12:33 AM
