My Car Is Falling On Its Face
Old Oct 16, 2003 | 06:06 PM
c0rey's Avatar
hey tonite i was just running open manifolds with enough pipe to be considered longtubes, it ran good for the first 30 mins of so, but it was still jerking at 4-5k like it was straving for fuel, the only code that i was getting was the low catalyst in bank one, could it be that i have a bad o2 sensor, after the car was warmed up it started to cut out at all rpms. could this mean i have a bad 02, in the manifold?? which is leaning out my car?
Old Oct 17, 2003 | 09:33 PM
Josh-'04 GTO's Avatar
It's tough to help out if we don't know anything about your car... The year is important, as that determines how many O2 sensors your car has. Assuming you have OBD II, if you have a code for post-cat on drivers side, then no, it will not car to lean out. It simply means that the cat on the drivers side is not performing properly. The sensor could also be bad.
As for the cutting out, those issues are usually ignition related. Have the plugs, wires, or opti been changed recently?
Old Oct 17, 2003 | 10:56 PM
mechmsb's Avatar
my car starved for fuel from 1-2k rpms and when i replaced wires did nothign i replaced coil did nothing then wheni replaced opti it was running like she used to nice and smooth and fast
Old Oct 18, 2003 | 12:05 AM
c0rey's Avatar
some say it could be my icm(ignition control module) since it only does it when the car is warmed up. it sounds reasonable to me
Old Oct 29, 2003 | 12:15 AM
c0rey's Avatar
edit the car info is in the sig, it only happens when the car is completly warmed up, could be be the Throttle Postioning Sensor, i have also heard it could be the coil, no burned wire or bad plugs.
anyone??
Jazsun
Dec 29, 2014 12:14 PM
ChrisFrez
Dec 15, 2014 03:09 PM
bernie1951
Dec 10, 2014 10:03 AM
USAirman93
Nov 24, 2014 03:37 PM
