Dummy O2
Dummy O2
If I get jethot lt's, will I need the dummy O2 sensors for the rear? Will not having them just set off a code, or will it affect performance? I assume I can have them programmed out along with the EGR and AIR.
Re: Dummy O2
thanks,
mark
You can have them programmed out with the air pump and egr... Why buy o2 sims if your gonna have the air and egr programmed out too... Wont cost you anymore to have those codes deleted out of the pcm.
Contact ION (madwolf) off the board. He does good programming and will work with you so that your a happy customer.
DanTheIROCMan
3rd Gen / L98 Engine Tech
May 2, 2004 02:18 AM
