relocating battery to the trunk
Old Oct 14, 2003 | 08:26 PM
bad95z28's Avatar
i need to pick up a fused t- terminal to run one wire from the battery and to split it off to the starter and alternator. anyone know where i can pick one of these up for cheap. the only one i have found is about $80 at a local car audio place. or maybe someone can tell me another way to do this.
michael
Old Oct 14, 2003 | 08:54 PM
BOTTLEDZ28's Avatar
try and find a way to get the factory wire and the new wire to be tightened together w/o cutting the factory wire. You may want to put your battery back in its orginal location down the road. I put a big terminal on the end of the new wire and then ran a bolt and nut through it and through the terminal on the factory wire. then I just covered it up and protected it
Old Oct 14, 2003 | 09:33 PM
bad95z28's Avatar
thats a good idea. can you buy screw on side mount terminals for batteries? i'm sure you can but i've never looked for one. if so, then using some way to fasten the two terminals would work well. i would like to be able to switch it back as well. that would definitely be easier than redoing the starter and alternator wires.
mike
Formula Steve
Sep 19, 2023 08:31 AM
Aaront810
Aug 29, 2020 09:34 PM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
