rough idle?? popping backfire..
Old Oct 14, 2003 | 03:20 PM
BigTed187's Avatar
I have a 95 z28 with some problems i cant seem to figure out...ive had a few people tell me the rough idle is coming from the o2 sensor but yet i still have a hesitation around 2000rpm when i first try to give it gas, but as i increase the gas it takes off just fine....can anyone help me??? thanx alot
Old Oct 14, 2003 | 03:48 PM
mechmsb's Avatar
uh oh
ok sounds like optis goin out i got new coil new plugs new iat sensor none of them fixed, then i did the opti presto it was fixed running like new...i diagnosed it with a scanner first though but I had identical symptoms as you.
Good Luck
Old Oct 14, 2003 | 03:53 PM
BigTed187's Avatar
another questoin if its the opti?? is this going to be an expenisve part?? and where can i get one from?? thanx
Old Oct 15, 2003 | 01:12 AM
96 WS6's Avatar
Do you have an exhaust leak? That can cause your symptoms.
Old Oct 15, 2003 | 03:42 PM
BigTed187's Avatar
Talking
nope no exhuast leak once so ever!!
Old Oct 15, 2003 | 03:56 PM
Wild1's Avatar
Opti-sparks can be expensive (relative term). Contact Jason Cromer and order your part from him to get a good price. I've seen them between the $275-$350 range.
Before I would replace the opti, I would recommend checking your plugs and wires. Keep It Simple.
At night, go to a really dark area without street lights and start your car. While in the dark, open the hood and wait about a minute or two to adjust your eyes. If you see sparks, then something is arcing from your plug wires to a ground. Sparks around the plugs are bad too... replace those plugs.
Remember, a blue corona haze is typically normal around a plug. You're looking for blue lightning sparks.
markzzzz
May 8, 2015 09:21 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
TrouserSnake
Jul 29, 2002 11:24 PM
