Loose Torque Convertor?
Old Oct 15, 2003 | 03:31 PM
TheCap10's Avatar
I'm rebuilding my LT1 and pulled the engine with the tranny attached. 1st time rebuilder and noticed that when I removed the engine from the tranny, the TC was loose. As in, it had approx 1in of play and I could wiggle it, in addition to turning it.
Is this normal? Or do I need to replace some bushing, overhaul, etc the tranny?!?!
Thanks!
Old Oct 15, 2003 | 04:30 PM
Z28SORR's Avatar
Your torque converter should turn freely in both the cw and ccw direction. With the trans. mounted to the engine there should be about an inch of for and aft play between the flex plate and and the trans. pump. With the trans. off the engine the torque converter should be able to move up and down (wiggle) a little bit.
Sounds normal to me!!
9t4lt4z28
Oct 2, 2015 10:28 AM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
