Mufflex Y pipe leaking in several spot?
Old Oct 15, 2003 | 01:21 PM
supermo26's Avatar
Question Mufflex Y pipe leaking in several spot?
I have Hooker LT and aMufflex Y pipe. I have tightened the clamps down to the point where they may brake if I go tighter. The Y pipe is still leaking in several spots. Has anyone found some clamps other than the ones that came with the Y pipe to seal it up right? I have adjusted the Ytwice but the clamps seam to be the weakest link. I'd like to buy some new clamps as long as I know they will work. No need to waste $8.00 per clamp if they don't work.
My Pass side o2 bung has a built up of carbon where it is leaking a little. I don't want to mess with it but I may have to send them back to get fixed and recoated.
Old Oct 15, 2003 | 01:45 PM
sleeperz28's Avatar
mufflex y-pipe is junk! mine hung very low and leaked at the catback. This was 3 years ago since I had it
Old Oct 15, 2003 | 06:13 PM
Transamdriver's Avatar
I had mine TIG welded, no leaks.
baron4406
Sep 15, 2002 07:42 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
