Security light fix
Security light fix
I know a lot of people have had this problem. I had it too, but was able to disable VATS using TunerCat for the time being. Anyway, I got fed up with the light and decided to take care of it. So I measured the resistance of my key pellet and went looking for the matching resistor. Once under the dash, I unplugged the connector attached to the two very small white wires with orange casing that run up the column and tucked it away. Then I jammed the resistor into the other part of the connector running to the VATS module, making sure the pins were wedged between the metal and plastic securely. Threw some electrical tape over it to hold tight, and buttoned things back up. Sure enough, about 60 seconds after starting the car, the light went out. Been fine since! No need to solder or otherwise permanently modify your beloved F-body. This is no more difficult than disabling CAGS for you M6 guys.
Originally posted by BLK96Z28
SWEET! I need to do this.
Where did you get the resistor?
I want to thank everyone on the vats problem...my 95 would not start one day,so i read all the things posted on here about "vats".I went to radio shack ,and got the resistor,hooked it up to the two wires ,and it started up with no problem ..sure beats going to the dealer and spending $500.00 to get the whole thing replaced.. thanks again
skippy45
skippy45
perfect my email is alfred559@yahoo.com, thanks man
hey skippy, could you please email me some pics also. i think i found the correct wires but just wanted to make sure. all you do is jump the connector with the resistor right? mehoffz24@aol.com thanks jack
If you ever want to share some images with everyone, I have an "image upload" section in my site that is easy enough to use.
http://www.technologyorgasm.com/upload/
Just follow the directions.
vats
http://www.technologyorgasm.com/upload/dsc00087.jpg
ok also pics 86-90
i hope this helps everyone ..
thanks vomit god
ok also pics 86-90
thanks vomit god
Just incase someone cant figure it out
http://www.technologyorgasm.com/upload/dsc00086.jpg
http://www.technologyorgasm.com/upload/dsc00088.jpg
http://www.technologyorgasm.com/upload/dsc00089.jpg
http://www.technologyorgasm.com/upload/dsc00090.jpg
It's no problem.. Feel free to upload all you want
