Flying air pump....
Old Oct 15, 2003 | 05:17 AM
S.J.S.'s Avatar
Flying air pump....
Okay I decided to fly the air pump. Fred mentioned getting 5/8" vacuum cap and M18 oil drain plugs. Where do I get them??? Any auto parts store.....Home Depot..... I have no clue and don't even know what the look like hahahahah.. (and here I am putting an engine together. HA!
Old Oct 15, 2003 | 05:38 AM
av8er's Avatar
I got my caps from NAPA.
JeffA
Old Oct 15, 2003 | 11:33 AM
S.J.S.'s Avatar
How many caps do I actually ned? And are those the ones?
Old Oct 15, 2003 | 11:38 AM
Hyperspeed97z28's Avatar
Are you running headers? or stock manafolds? If stock I believe its m18 if its headers say 93-95 style then its m22 drain plug.. You can get them at napa...
Old Oct 15, 2003 | 01:53 PM
S.J.S.'s Avatar
I'm running SLP shorties. Oh yeah, what about that tube that goes inder the motor? Doesn't it go to the back of the passenger side head? Maybe I'm wrong but if so don't I need to cap that? My motor is going back in this coming week and I forget what it looked like.
Old Oct 15, 2003 | 07:48 PM
S.J.S.'s Avatar
ttt....cummon dudes....
Old Oct 15, 2003 | 08:23 PM
gb95zconv's Avatar
Are you talking about the EGR tube....comes off the passenger side header and goes to the intake manifold. If so...I just block it off and get rid of the egr crap too.
Now the tube that goes under the motor in the front is part of the AIR and you can trash that if your removing AIR.
Old Oct 15, 2003 | 08:57 PM
CamaroBoy96Z28's Avatar
He's talking about the AIR crossover tube. Mine's still there. Havent been able to take it out yet. You can just leave it if you want.
It doesnt go to the pass. side head. You're confusing the coolant crossover hardline behind the heads. The AIR crossover just goes under the motor and hooks up to the AIR fitting the same way as the driver's side. Think of it as a big "U".
Old Oct 16, 2003 | 04:12 AM
S.J.S.'s Avatar
Okay...but both heads in the back have these holes that something bolts too. Guys forgive me if I sound like an idiot which I do. I just got my motor in pieces and trying to do everything at once. P&P heads. hook up coolers, gauges, put motor together. I'm just confussed right now. But anyway, what are those tubes that go behind each head?
Old Oct 16, 2003 | 04:14 AM
S.J.S.'s Avatar
I found it on Shoeboxes site. It is the EGR pipe to the exhaust manifold. Okay next question......what part of the manifold does it attach to???? lol. Remember I got SLP shorties.
Old Oct 16, 2003 | 07:47 AM
here's the link for EGR block off plates.... http://www.mycamaroz28.homestead.com/
Can someone confirm if this is the right size equal to an m-18 drain plug? " 3/4-16 x 3/4 ??
Old Oct 16, 2003 | 07:57 AM
Dude, do yourself a favor and get a manual. The line going to the back of the heads is a coolant line.
Old Oct 16, 2003 | 10:28 AM
gb95zconv's Avatar
Like shoebox said .....get a manual....if you think your confused now wait till you start hooking the harness back up.
Old Oct 16, 2003 | 11:47 AM
S.J.S.'s Avatar
Sorry to **** you guys off. But I looked all through the manual and I couldn't find a pic or anything that says what those lices were. Like I said I got so much going on. INFO OVERLOAD. But thanks all.
Old Oct 16, 2003 | 11:52 AM
I hardly take Shoebox's comments as in indication that he is "pissed off"..... he is only trying to help you understand that it is a he!! of a lot easier to do this kind of stuff if you use a good manual. There is an awful lot of incorrect info that gets posted on these threads..... I wouldn't rely on the internet to assemble an engine.
