Link Error w/ dyno???
Old Oct 14, 2003 | 04:25 PM
BigTed187's Avatar
I have a 95 z28 and i was wondering why evertime i get the dynostics done, it comes up "Link Error"...i was wondering if i have a wire disconnected somewhere?? can anyone tell me where this problems occuring??
thanx
Old Oct 14, 2003 | 04:29 PM
Your 1995 is confusing to many shops..... Although your 1995 has a 16-pin OBD-II ALDL connector, it runs an OBD-I PCM. The shop is connecting an OBD-II scanner, and of course, it will not connect. They need to run an OBD-I scanner, with the proper "cross-over" connector.
Old Oct 14, 2003 | 05:43 PM
BigTed187's Avatar
so the cross over is already with the OBDI?? or do i have to get a cross over for it??
Old Oct 14, 2003 | 09:35 PM
You need a "connector" that connects the data pin of a 12-pin OBD-II connector, to a 16-pin OBD-II connector, but with the data pin in a different position. Check:
AKM Electronics
He can fix you up with the correct connector. Or some shops may have the connector... I know Auto Xray supplies one with their OBD-I scanner. First, verify with the shop that the problem is what I described. It's about a 99% sure thing that this is the problem, but you should verify it.
realistyc
Jul 28, 2015 07:32 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
asilomar244
Jul 12, 2015 05:53 AM
