radiator question
Old Oct 15, 2003 | 03:55 PM
ReznorZ28's Avatar
Unhappy radiator question
Well I just got a new radiator installed a couple days ago... and today it seems to be leaking bad.... I cant really look into it too much at the moment because its pretty hot. But just looking at it, it seems that the low coolant sensor popped out somehow. I cant see it all too well, but it looks like it plugs into the radiator like a cork. If so, thats the source or my leak right? If anyone knows please fill me in. thanks
Old Oct 15, 2003 | 04:00 PM
There is a retainer that holds in place.
Old Oct 15, 2003 | 04:01 PM
Wild1's Avatar
I can't confirm the mount since I've never replaced one. But I doubt that it is pressure fit. Considering that the radiator goes up to 16 PSI with heat, I doubt a pressure fit will hold. Likely a tab may have been damaged on the connector or mount that locks it into place.
Old Oct 15, 2003 | 04:04 PM
Wild1's Avatar
Shoebox, we replied at the same time. In fact, I was just looking on your website to find him an illustration. Great job again!
Old Oct 16, 2003 | 08:38 AM
ReznorZ28's Avatar
Unhappy
where are those wire clips supposed to be attached to? Because they appear to come right off with the whole unit...
Old Oct 16, 2003 | 10:19 AM
I assume they lock on to the bracket on the radiator to keep the sensor from popping off.
Old Oct 17, 2003 | 12:45 PM
ReznorZ28's Avatar
well I took it back to the radiator shop because appearantly they didnt correctly attach the bracket back on to the radiator... they said sorry and supposouvly fixed it. Hope it doesnt happen again because it could screw up my opti.. thanks for you help
Old Oct 17, 2003 | 01:07 PM
Wild1's Avatar
Did you lose any coolant when it popped out? Then you might have an overheat condition. Mine has never popped off so I am not certain that you would lose coolant.
Old Oct 17, 2003 | 01:17 PM
ReznorZ28's Avatar
yes I did... but my temperature guage read fine...
Old Oct 17, 2003 | 03:49 PM
Wild1's Avatar
Seems like you caught it in time. Typically any type of pressure loss (leak) would lower the boiling point. Air bubbles from the boil will create hot spots in your reverse cooled heads. Those hot spots can warp and cause problems down the road. Just to be sure, did you use the two bleeder valves to remove the air from your system. I'd double check and do it regardless of what the radiator shop says... just to be safe.
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
grgguy
17
Feb 23, 2015 07:57 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
