How do you remove the oil pump shaft??
Old Oct 17, 2003 | 02:31 AM
john-e-boy's Avatar
I got a new hardened oil pump shaft for my rebuild and I am not sure how to remove the shaft off of the gear??
So basically How do you seperate the gear from the shaft??
John
Old Oct 17, 2003 | 05:40 AM
slopokrodrigez's Avatar
I'm a little confused. The gear that runs against the cam shaft is on the short shaft that drops in from the top under the intake manifold. This gear is not replaceable, you have to replace the whole short shaft. The other shaft that fits into the end of the short shaft and mates to the oil pump doesn't have a gear on it.
That is if you're talking about an LT1 with reverse cooling.
Old Nov 2, 2003 | 12:04 PM
john-e-boy's Avatar
I am trying to seperate the shaft, the long shaft with the plastic sleeve on it, from the oil pump gear that sits in the housing. How does it come apart??
John
Old Nov 2, 2003 | 10:57 PM
john-e-boy's Avatar
TTT
Old Nov 2, 2003 | 11:13 PM
NOMAD's Avatar
Cool
John
It just pulls straight up, nothing holding it in there.
-Shannon
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
TrouserSnake
Jul 29, 2002 11:24 PM
