Tube From Back of Intake to Exhaust???
Old Oct 16, 2003 | 01:06 PM
HectorM52's Avatar
What is it? What does it do? I want to remove it, do I just plug both ends and go from there? Is there something I need to do in the PCM program to make it not throw a code or something?
Old Oct 16, 2003 | 01:10 PM
NVetro's Avatar
that is the all mighty EGR (Exhaust Gas Recircultation). You can remove it, but then you will need to block off the intake and exhaust side with plates. You have OBD1 so you will not throw a code, obd2 will.
1msfyter's Avatar
thats your EGR tube. , right next to it is a vacumm activated valve that lets in exhaust gas. There was a big write up about it about a week ago. You wil need 3 block off plates to completely remove it. As for throwing a code it depends if you have OBD1 or OBD2.
Old Oct 16, 2003 | 01:15 PM
GREGG 97Z's Avatar
Here is a pic of the back of the intake with the two block off plates installed after I removed my EGR system. You need one more just like the small one on the right to block off the hole in the exhaust manifold. I made the one on the right and the one for the exhaust. The big one on the left I bought from the dealer for like $6.
Old Oct 16, 2003 | 01:18 PM
HectorM52's Avatar
Greg,
Do you know which hoses you plugged on the side of the intake? Or is it just the ones associated with the EGR pump?
Adam
Old Oct 16, 2003 | 01:29 PM
GREGG 97Z's Avatar
Originally posted by HectorM52
Greg,
Adam
I believe there was just one line that ran from the EGR vacuum solenoid to a fitting in the middle of the driver side of the intake manifold. I just removed that and plugged it with a vacuum plug.
HectorM52
Jul 30, 2017 11:46 AM
Killer94z
Jan 13, 2015 12:06 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
