Valve Covers for 1.6RRs????
Old Oct 16, 2003 | 11:12 PM
GpMike24's Avatar
Exclamation Valve Covers for 1.6RRs????
i have a CC306 Cam, 1.6 RRs, crane valve springs and need some valve covers for my LT1 please give me some good suggestions for what will fit and any pics if you have any.
Old Oct 16, 2003 | 11:17 PM
AsianSensation's Avatar
No problems with GMPP 1.6rr with the Corvette valve covers. See pic.
http://www.97ta.com/lt4/lt511.jpg
Old Oct 16, 2003 | 11:19 PM
GpMike24's Avatar
know the GM part # by chance?
Old Oct 16, 2003 | 11:22 PM
bad95z28's Avatar
the stockers will work fine unless you're just wanting to upgrade. i opted for the LT4 valve covers.
michael
Old Oct 16, 2003 | 11:24 PM
GpMike24's Avatar
so is there really any need to upgrade, wouldnt mind savin a lil $$ if stock will work just fine
Old Oct 16, 2003 | 11:31 PM
bad95z28's Avatar
nope save the money for now. you can always add them on later and it will only take about 10 minutes to swap them out. easiest thing you can do on a f-body. i've heard of a couple people having to clearance the inside just a hair but everyone that i personally been around has had no problems with the stockers. the only thing that you can gain is if you go with the LT4 valve covers. they are composite instead of metal and they are designed to reduce some of the noise created by roller rockers. just take care of that issue with your tuning and watch for false knock. usually tuning and an LT4 knock module will take care of this.
michael
Old Oct 16, 2003 | 11:42 PM
Bud M's Avatar
You can use the stock covers, you just need to remove a bit of metal from the supports inside the covers. A grinder and a cutting disc will do the trick. Clean them out well afterwards and you're good to go.
Old Oct 17, 2003 | 08:13 AM
BradZ28's Avatar
I need to do this tonight! Does anyone have pics of stock clearanced valve covers for 1/6rr? Sorry to steal your post but I figured you could use this too.....
Brad
Old Oct 17, 2003 | 08:54 AM
BradZ28's Avatar
http://www.hotss.com/Members/scott_vaca/Cam2.htm
At the bottom of the page is what we are looking for, Shoebox said this is the clearest pictures of the valvecover mod he has seen..... Is this what everyone else has done?
Brad
Old Oct 17, 2003 | 09:19 AM
jim88iroc305's Avatar
141-130
GM 12497978
http://www.salleechevrolet.com/Profo...ve_covers.html
Had to grind rear top and bottom of alternator to fit.
Old Oct 17, 2003 | 08:12 PM
Bud M's Avatar
http://www.hotss.com/Members/scott_v...vcovr-mod4.jpg
That's exactly how I did mine.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
