who has removed their EGR.. ?
Old Oct 15, 2003 | 08:40 PM
ninetythreez's Avatar
1.how did you remove it?
2.block off plate and where to get one or did you make one?
3.Effects on other parts of motor or computer codes?
Thanks!
Old Oct 15, 2003 | 08:48 PM
CamaroBoy96Z28's Avatar
1. Removed the EGR components. Solenoid, EGR tube (intake-exh. manifold), blocked off open holes with vacuum plugs which I believe 3/8". Also removed AIR at the same time.
2. SJM Manufacturing. The site address is posted in every single !EGR thread which emerges every other day.
3. OBDII cars set a code. I have an eternal SES light until I get it programmed out. OBDI cars dont set a code 95% of the time.
Old Oct 15, 2003 | 08:52 PM
QCKZ28's Avatar
1. when i did headers, i removed the egr tube from the manifolds and trashed it, removed the EGR valve from the back of the intake manifold.
2. i made my block off plates (3 of them, one for the headers,and two for the intake manifold) from a sheet of steel with my dremel tool. i used RTV and new gaskets to make them seal.
3. it did not set my SES off in my obd2, although removing the air pump did. but it will throw a code.
hope this helps.
Old Oct 16, 2003 | 09:15 AM
RallyRed701/2's Avatar
i always see it talked about... but i can find the actual site address to sjm manufacturing... anyone with the exact site???
Old Oct 16, 2003 | 09:41 AM
http://www.mycamaroz28.homestead.com/
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
