a bad Opti spark, can it cause backfiring?
Old Oct 16, 2003 | 09:42 AM
NewbieWar's Avatar
well, im trying narrow down my major problem
after the car is warm it will start backfiring and hesitating between 1000-2000 rpm's
but if i step on the gas it works
there is a hissing sound in tune w/ the engine, and im pretty sure thats EGR
but what gets me, is that the backfiring seems to only happen when the engine has warmed up... so to me that sounds like it has something to do with the O2...
the EGR is a cheap replace but i donno how that would be done, my haynes book doesnt do a very descriptive replacment/repair portion on that subject.
its not having any trouble starting or anything, with limited funs what should i repair first? EGR, opti, or possibly O2
Old Oct 16, 2003 | 11:26 AM
TechCam97's Avatar
Yea, a bad opti can make your car backfire. Mine does it every once-in-a-while, but my opti is on its way out, not completely gone yet. It is kind of funny when it happens, it scares people s#itless on the road. I have no cats and a cutout, so once when I nailed it and it backfired, my friend behind me saw a flame shoot out the cutout! lol, scared the living **** out of him, he thought I fudged something up. Check plugs and wires as well. I found a couple on mine that were so loose I could screw them around with my fingers! I don't know how they got so loose, but I check them every other week or so. Good luck with the diagnosis though!
Old Oct 16, 2003 | 11:59 AM
NewbieWar's Avatar
but the backfires only happen thro acceleration thro 1000-2000 rpms... would this be true for u guys as well?
i dont thinks its really loud tho, its just a little *Bumb* and the peddle gives a little bump...
would this be the same for u guys?
Old Oct 16, 2003 | 05:14 PM
TechCam97's Avatar
Yea, that happens in mine sometimes as well. Check your plugs and wires first though. Then check the coil. If everything checks out, just go buy a rebuilt one from Autozone and call it a day.
Old Oct 16, 2003 | 05:28 PM
CamaroCasanova's Avatar
Mine blew flames out the back, like full on fire. Sounds like the OPTI to me.
Old Oct 16, 2003 | 05:48 PM
revtime's Avatar
If its backfiring under accleration then you have ignition problems, my guess is a bad cap and rotor, this is exactly what mine did when they went.
Might as well throw a complete new opti in.
grabbem88
Mar 18, 2015 01:25 PM
maybe2fast
Mar 16, 2015 11:59 AM
Iamherefornow
Jan 26, 2015 04:57 PM
USAirman93
Nov 24, 2014 03:37 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
