Effects of plug gap....
Old Oct 16, 2003 | 08:00 PM
96z's Avatar
96z
Can too much or too little of a plug gap effect smoothness, etc of an engine, or maybe even a miss? Im running a .050 gap right now, could that possibly be too much for my mods? I know people with nitrous go with a smaller gap b/c the nitrous could possibly blow out the spark...
Any ideas?
Old Oct 16, 2003 | 10:08 PM
96z's Avatar
96z
Anyone have any idea??
Old Oct 16, 2003 | 10:18 PM
IMO, I would not change the plug gap unless you are spraying or blowing.
Old Oct 16, 2003 | 11:06 PM
96z's Avatar
96z
Glad someone had something to say. Just wondering shoebox..what possible bad could come from running say an .040 gap?
Old Oct 16, 2003 | 11:51 PM
I'll let NGK say something about gap:
Always check that the spark plug gap is compatible with the engine manufacturers specification. A gap that is too small means that the spark duration will be very quick and the spark will be thin and weak. The consequences of this may be bad starting and high exhaust emission levels. This will result in an increase in fuel consumption. If the gap is set too large, the ignition system will not be able to cope with the demands and a misfire situation will occur. Some wide gap spark plugs have a longer ground electrode to accommodate a wide gap setting. These must be used where specified, as opening up a standard plug to a wider gap setting may result in the electrodes not running parallel to each other. This could result in abnormal and premature electrode wear.
From another source:
Insufficient spark plug gap can cause pre-ignition, detonation, even engine damage. Too much gap can result in a higher rate of misfires, noticeable loss of power, plug fouling, and poor economy.
When you raise compression or add forced induction (a turbo system, nitrous, or supercharger kit), you must lower the gap (reduce gap about .004" for every 50 hp you add on an V-8 engine). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology,) you can open the gap back up about .002"-.005".
As an example, let's use a hypothetical `96 350 Chevrolet LT1 engine build-up. The standard gap is .050" for an un-modified LT1. We'll add 150hp Nitrous, so we must lower the gap about .012" to .038". We then decide to add that killer MSD 6A/Crane Hi-6 box and, using our guidelines as outlined above, we can now open the gap up .002"-.005" to about .040"- .043". By following this basic guideline should get you very close.
Further experimentation may be necessary, but by always starting with a larger gap than it thought necessary to reduce the risk of detonation, you should be safe.
Depending on your mods, you might experiment a little.
Old Oct 17, 2003 | 06:56 AM
96z's Avatar
96z
Great info, thanks again shoebox.
Old Dec 1, 2003 | 03:39 PM
Fastbird93's Avatar
I think this is deserving of a TTT. I'm going to give a smaller gap a shot and see if that helps my stumble out along with the new wires. I figure I added 100+ hp at the flywheel with the head/cam setup.
This is good info in this thread.
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
Jan 23, 2015 01:13 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
