car runs then dies and will not start
Old Oct 14, 2003 | 08:31 PM
shootcallerz28's Avatar
I have change the Icm,coil,fuel pump relay.The car will start then run for a while today it was nine mins.then it will startto backfire a little then cut off.I will try to crank again all it will do crank for a sec then cut off. The opti is 6 mouths old put on at the dealership.I wounder is it the fuel pump do any one know what can cause this i have not driven my car sense satday.Inotice my rpm gauge gose up and down before it cuts off. thanks
Old Oct 20, 2003 | 06:50 PM
slopokrodrigez's Avatar
what is your fuel pressure during all of this? Tape a hose type gage to the windshield and check it out.
Old Oct 20, 2003 | 08:05 PM
Hotwire's Avatar
hey shootcaller,
I live in summerfield which is 10 min north of greensboro.
what year car do you have? do you have the rubber elbow securely fastened to the throttle body? scanned for codes? i might be able to swing by and help you out if you need it.
Jeff
Old Oct 20, 2003 | 10:29 PM
thumpinTA's Avatar
If it is the opti dont feel to bad. I replaced mine last spring with my new cam. That died 2 months later. I had someone else replace it and that 1 died in a month with the exact same symptoms you are talking out. I said the heck with it and will deal with it next spring. My car is a 94 and i put the vented 1 on and did not conect the vacuum line thinking it was nota big deal. That could be the source of my problems. Are yours hooked up the right way?
Noenav
Mar 1, 2019 07:38 AM
ro2207
Dec 4, 2014 06:18 PM
Ricardo
Nov 29, 2014 10:58 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
