Exhaust Manifold Gaskets
Old Oct 16, 2003 | 09:11 AM
b-stevens's Avatar
How much do these go for and where could I pick these up? before I get headers I need to do a catback first, and I'd like to see if my exhaust leak... at least i think thats what it is... is fixable. I can hear a ticking on acceleration. Would it be noticeable if the exhaust manifold gaskets were blown out just by looks or feel? I'm also wondering if it could be my rockers ticking, because i can definately hear ticking more on the drivers side than on the left at idle. This might just be my imagination though. Are there gaskets I would need to replace for my valve covers?
Plus just having the knowledge of replacing the exhaust manifold gaskets might make me brave enough to attempt the install header install myself when i get around to them. Save a few hundred dollars.
Old Oct 16, 2003 | 10:21 AM
IDOXLR8's Avatar
I think if you get GM OEM gaskets from the dealership they are like 17.00 a piece.
Old Oct 16, 2003 | 10:36 AM
Stoopalini's Avatar
Check your collector/flange gasket on the drivers side ... I bet it's leaking. This is the gasket at the bottom of the manifold, not the one where it connects to the head. It's a pretty common exhaust leak.
Thomas.
Old Oct 16, 2003 | 12:11 PM
TMD95Z28's Avatar
get a fepro exhaust manifold gaskets. It's not more than $25. oh try to install the exhaust manifolds urself, i'd installed my headers in less than 8 hours(guess i'm still a beginner . with the sparkplug wires too..
so goodluck in changin.
Old Oct 16, 2003 | 12:35 PM
Mystic97Z's Avatar
i heard a metal ticking noise under acceleration for al ong time also, my dad is a technician, and he swore it was a loose rocker arm, it turned out to be an exhaust manifold gasket.
Old Oct 16, 2003 | 01:35 PM
b-stevens's Avatar
Yeah im not sure if its the rockers I was going to check my drivers side before school but then i realized oil + clothes + no time = not so good....
Does anybody have a problem of the battery shaking somewhat violently in park at idle? If i just lightly restrain it it stops, is this a battery bracket/mount or whatever or is this somewhat normal
Old Oct 16, 2003 | 01:36 PM
Mtrhds94Z's Avatar
Check for a broken bolt too.. seems common on these engines especially the rearmost drivers side..
69z-28
Jan 29, 2016 10:46 PM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
