What else do I need with the cc306?
Old Oct 14, 2003 | 03:30 PM
Javier94z28's Avatar
Question What else do I need with the cc306?
I only have the cam, thats it, i really dont know what to get, i have a stock bottom end. thank you , should i get head`s to
Old Oct 14, 2003 | 03:44 PM
mebanditws6's Avatar
You will need to upgrade just about everything else such as stiffer springs, better retainers, good lifters, hardened pushrods w/guideplates to best handle the 6500 or so shiftpoints. I don't know the lift with 1.5 rockers, but 1.6's will compliment the cam well.
Oh, you MUST get your heads ported to take full advantage of this cam, otherwise it won't make near the power it should. A good stage II type port job will be best. You'll have a strong running beast once this is done. Make sure you get the pcm tuned by Bryan, as a stock pcm will freak out with a cam this size. good luck
Jason
Old Oct 14, 2003 | 03:45 PM
SloMofo's Avatar
What would I need to get with a cc305? I'll be sticking with stock RRs for now
Old Oct 14, 2003 | 03:46 PM
Oh one more thing, stick with comp cams for the other valvetrain parts. If you're not sure on what to get, give them a call. Other than springs it's pretty straightforward in matching up the valvetrain with the cam.
Jason
Old Oct 14, 2003 | 04:10 PM
SloMofo's Avatar
ugh! That all adds up to too much $ right now =/
Old Oct 14, 2003 | 05:55 PM
Z95m6's Avatar
get ported heads.
Old Oct 14, 2003 | 11:10 PM
SloMofo's Avatar
Anyone else?
Old Oct 14, 2003 | 11:55 PM
Transamdriver's Avatar
You dont need to port the heads, plenty of people are making lots of power with stock heads. When I did the CC306 I kept the stock lifters but got Crane 10308-1 springs/retainers, Comp pro mag 1.6 rockers, Comp Chromemoly pushrods,and a AFR hydra rev kit.
Old Oct 15, 2003 | 12:57 PM
How long did they last after the swap?? I personally wouldn't trust stock lifters especially over 100k with that kind of seat pressure from those springs and retainers.
Jason
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
